How can I convert bolted connections to welded-plate connections after defining trusses?
Selecting Truss Connections:
If the cross-section of the truss elements is double equal-leg angle 2L:
Click the truss macro twice to open the truss properties window.
The connection type is selected from the "connection type" in the right bottom section of the section tab.
Welded + Plate option can be used.
Bolted + Plate option can be used.
If the cross-section of the truss elements is circular or box profile;
The welded option can be used.
