Welded Flange Plate Connection Design
The Welded Flange Plate Connection is formed with butt welded welded head plates with cotton penetration to the column head and corner welded to the beam head. Body plate bolt control, welding control, plate control and connection application limits control are made automatically according to the placement of the elements of the connection. Welded Flange Plate Connection design is made automatically according to the Design, Calculation and Construction Principles of Steel Structures (ÇYTHYEDY) or AISC 360-16 regulations and a connection report is created.
In the calculation of the Welded Flange Plate Connection, the header plate and slip plate weld thickness, slip plate column head weld thickness, continuity plate - column head and body weld thickness are checked under geometry control. Head plate weld strength, header plate tensile failure, block slip at beam head, pressure plate leakage, slip plate weld strength, shear plate beam body strength, body plate shear failure, body plate bending yield, column panel region slippage are checked.
Connection Geometry
Geometry Checks
Flange Plate to Beam Flange Weld Size
6 mm
4 mm
Table 13.4
Shear Plate to Beam Web Weld Size
6 mm
3.5 mm
Table 13.4
Shear Plate to Column Flange Weld Size
6 mm
3.5 mm
Table 13.4
6 mm
4 mm
Table 13.4
6 mm
4 mm
Table 13.4
Strength Checks
Flange Plate to Beam Flange Weld Strength
520 mm
280 mm
490 N/mm2
in
8.487 mm
410 N/mm2
410 N/mm2
16 mm
18 mm
Required
Available
Ratio
Control
143.884 kN
1140.426 kN
0.126
Flange Plate Tension Yield
275 N/mm2
ÇYTHYEDY 13.15
Required
Available
Ratio
Control
143.884 kN
1108.8 kN
0.130
Flange Plate Tension Rupture
410 N/mm2
1.00
ÇYTHYEDY 13.16
Required
Available
Ratio
Control
143.884 kN
1377.6 kN
0.104
Beam Flange Block Shear
275 N/mm2
410 N/mm2
1
ÇYTHYEDY 13.19
Required
Available
Ratio
Control
143.884 kN
1269 kN
0.113
Flange Plate Compression Yield
TO
0.65
L
20 mm
r
4.619 mm
KL / r
2.81
275 N/mm2
ÇYTHYEDY 13.20
(KL/r<25)
Required
Available
Ratio
Control
143.884 kN
1108.8 kN
0.130
Shear Plate to Column Flange Weld Strength
in
8.487 mm
490 N/mm2
l
260 mm
is
117.5 mm
Required
Available
Ratio
Control
15.529 kN
374.02 kN
0.042
490000 kN/m2
in
The weld thickness taken from the combination menu is 0.707 * w value. 6 / 0.707 = 8.487 mm
410  N/mm2
t
10 mm
Required
Available
Ratio
Control
66.153 kN/m
1323 kN/m
0.042
Web Plate Shear Yield
275 N/mm2
ÇYTHYEDY 13.17
Required
Available
Ratio
Control
15.529 kN
429 kN
0.036
Web Plate Shear Rupture
410 N/mm2
ÇYTHYEDY 13.18
Required
Available
Ratio
Control
15.529 kN
376.38 kN
0.041
Web Plate Flexural Yield
260 mm
275 N/mm2
10 mm
117.5 mm
Required
Available
Ratio
Control
15.529 kN
273.948 kN
0.057
Column Panel Zone Shear
1621.397 kN
ÇYTHYEDY 13.29a
275000 kN/m2
28634.759 mm2
650 mm
16 mm
Required
Available
Ratio
Control
103.141 kN
1544.4 kN
0.067
