Earthquake Ground Motion Level.
  • According to Codes, Earthquake Ground Motion Level and Performance Level are determined automatically.
  • According to Codes, design response spectrum with 5% damping ratio, determined automatically based on user defined map acceleration parameters and site coefficients.
International Design Codes
ASCE 7-16 : Ground Motion Levels per ASCE 7-16 with ideCAD
TSC 2018 : Earthquake Ground Motion Levels
Within the scope of Seismic Design Codes, different earthquake ground motion levels are defined. Design earthquake spectrum are defined in a standard form based on map acceleration parameters and site coefficients for 5% damping ratio based on a specific earthquake ground motion level.
The Risk-Targeted Maximum Considered Earthquake, spectral magnitude of 2% probability of exceedance in 50 years and the corresponding return period of 2475 years is very rare characterizes the earthquake ground motion.
Design Earthquake Ground Motion, spectral magnitude of 10% probability of exceedance in 50 years and the corresponding return period of 475 years is called Design Earthquake Ground Motion.
Site Class.
