How to add a project file to the customers portal with cde extension?
Compress, save and add the ideCAD project file you want to add to your question.
  • Click on the ideCAD logo.
  • Save by clicking " Save Compact " from the menu that opens.
  • This saved file will have the extension "*.cde" and the file size will be very small.
  • In the customers portal, click the File Attachment section Browse button.
  • Find the location of the file you want to add to your question from your computer, select the file and press the Open button.
  • The file you selected will be loaded.
  • When the installation process is finished, the project file with the .cde extension will be added to your question.
