How do I rotate the structure?
You can rotate the structure in any angle you want by using the Rotate Building command under the Tools tab.
  • Click on the Rotate Building icon under the ribbon menu tools tab tools title.
  • The Rotate Building dialog will open.
  • Give the angle value and click the OK button.
  • The structure will be rotated as much as the entered angle value.
