Creating a Sheeting Between Elements
With the Sheeting Between Elements command, a sheeting element is created between the building elements. Sheetings are load transfer elements.
Location of the Sheeting Between Elements Command
  • Click the Sheeting Between Elements icon from the ribbon menu.
  • Select the first element you want to sheeting.
  • Select the second element.
  • The sheeting will occur automatically.
Before creating a sheeting between elements
Selection of the first element
Selection of the second element
After creating a sheeting between elements
Space Truss
