For example,
SC001 BASE STORY Section dimensions do not conform toTBDY Table 9.3.
Width-to-thickness ratios of highly ductile beams and moderately ductile beams are checked in accordance with AISC 341-16 Table D1.1 and TBDY Chapter 9. Limit values of Width-to-thickness ratios λ hd or λ md are given in AISC 341-16 Table D1.1.
For detailed information, you can review the titles below.
Width-to-Thickness Ratios for SMF per AISC 341-16 with ideCAD
Solutions:
The cross-section of the steel element whose name and floor are given can be changed.
Steel beam cross-section selection can be made to reduce the header width/thickness or body height/thickness ratio.
If it is possible, a moderate ductility level can be selected.
AISC 341-16 Table D1.1 is given below.
Limiting Width-to-Thickness Ratios for Compression Elements for Moderately Ductile and Highly Ductile Members |
Description of Element |
Width-to- Thickness Ratio |
Limiting Width-to-Thickness Ratio |
Example |
λhd
λmd
Flanges of rolled or built-up I-shaped sections, channels and tees; legs of single angles or double-angle members with separators; outstanding legs of pairs of angles in continuous contact |
b/t |
Flanges of H-pile sections per Section D4 |
b/t |
not applicable |
Stems of tees |
d/t |
Walls of rectangular HSS used as diagonal braces |
b/t |
Flanges of boxed I-shaped sections |
b/t |
Side plates of boxed I-shaped sections and walls of built-up box shapes used as diagonal braces |
h/t |
Flanges of built up box shapes used as link beams |
b/t |
Webs of rolled or built-up I shaped sections and channels used as diagonal braces |
hw/t |
Where used in beams or columns as flanges in uniform compression due to axial, flexure, or combined axial and flexure:
b/t
h/t |
Where used in beams, columns, or links, as webs in flexure, or combined axial and flexure:
h/tw
h/t
h/t |
For Ca ≤ 0.114
For Ca > 0.114
where
For Ca ≤ 0.114
For Ca > 0.114
where
Webs of built-up box sections used as EBF links |
h/t |
Webs of H-Pile sections |
h/tw |
not applicable |
Walls of round HSS |
D/t |
λhd : Limiting slenderness parameter for highly ductile elements
λmd : Limiting slenderness parameter for moderately ductile elements
