With the Unstiffened Seated Connection command, column-beam connection is defined.
Location of the Unstiffened Seated Connection Command
From the Connection menu, click on the Unstiffened Seated Connection icon.
The unstiffened seated connection settings dialog will open.
Location of the Unstiffened Seated Connection Settings Dialog
Type and Placement Tab
Connection to support
Bolted or welded connection types are selected for the support connection. |
Connection to beam
Bolted or welded connection types are selected for the beam connection. |
Placement Placement values are entered. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Connection and placement values are shown on the schematic drawing. |
Preview
Angle Tab
Define plate geometry
If the option is selected, it is determined by entering the angle values. The values to be entered are shown in the schematic drawing. |
Use section
By selecting the option, one of the ready-made L profiles is selected from the list as an angle bracket. By clicking on the load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list. |
Length
Angle length value is entered. |
Schematic drawing
Preview
Top/Bottom Notch Tabs
Notch
If the option is selected, notching is done according to the entered values. The values to be entered are shown in the schematic drawing. |
Left flange cut
If the option is selected, left flange cutting is made according to the entered values. The values to be entered are shown in the schematic drawing. |
Right flange cut
If the option is selected, right flange cutting is made according to the entered values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Stabilizer Tab
Connection to main part
Bolted or welded connection types are selected for the main part connection. |
Connection to connecting part
For the connected part connection, one of the bolted or welded connection types is selected. |
Type
It is selected whether the connection will be on the left or right or on the top of the beam body. |
Stabilizer Profile Tab
Use section
Length
Schematic drawing
Preview
Stabilizer Bolts Tab
Horizontal arrangement
The horizontal arrangement settings (number of horizontal bolt columns, distance values ..) of the anchor bolts are entered. The values to be entered are shown in the schematic drawing. |
Group 1
Stabilizer bolts settings (number of lines, distance values ..) are entered. The values to be entered are shown in the schematic drawing. |
Bolt properties
Schematic drawing
Preview
Beam Bolts Tab
Beam bolts horizontal arrangement settings (number of horizontal bolt columns, distance values ..) are entered. The values to be entered are shown in the schematic drawing. |
Group 1
Beam bolts settings (number of lines, distance values ..) are entered. The values to be entered are shown in the schematic drawing. |
Bolt properties
Schematic drawing
Preview
Welds Tab
In the welds tab, the weld properties of the connections given in the schematic representation are set.
Welds
Schematic drawing
Connection and source values are shown on the schematic drawing. |
Preview
Design Data Tab
