The steel crane beam design results and the failure conditions of the crane beams are displayed in the Crane Beams dialog. In the Crane Beams dialog, the material and section properties of the crane beams, biaxial bending interaction ratio, deflection control and body crease controls are displayed.
Location of Crane Beams Dialogue
After the analysis is done, you can access it by clicking the Crane Beam Design Results command under the Steel Design heading in the ribbon menu Analysis and Design tab .
General Specifications of Crane Beams Dialogue
Summary Information The summary information about the line where the cursor is located is given in the name of the dialog in Layer, pose format. For example GROUND FLOOR, CRN001 |
Using the Shift key In this tab, you can select more than one row with the Shift key, enter a value by double-clicking any cell whose value is open to change, and make that value apply to all selected rows. |
Using the Ctrl key Ctrl key selects the lines in between one by one. |
OK It saves the changes made and closes the dialog. |
Crane Beams
Design Controls Tab
ID
It is the name of the crane beam in the plan. |
Section
It is the section used in the crane beam. |
Material
It shows the material class of the crane beam. |
Biaxial bending
The ratio of biaxial bending moment to capacity. |
Shear
The ratio of the shear force acting on the crane beam to the capacity. |
Web sidesway buckling
The ratio of maximum wheel load (including crash) to body crunch strength. |
Deflection
The ratio of deflection made by the beam to the limit value. |
Check
Information box whose sign changes according to the situations of exceeding or not exceeding the design limits. |
Design Details Tab
Design code It is the regulation on the design and controls of the crane beam. |
Crane beam info
ID: It is the name of the crane beam in the plan.
Biaxial bending
Mu3: It is the moment value acting on the element in the 3 direction.
Shear
Vu: It is the shear force acting on the element.
Deflection
Max vertical deflection due to wheel loads: It is the deflection formed in the beam under the loads applied by the wheels to the beam.
Max. wheel load (including impact): Max. wheel load.
