Block Drawings
With the "Make block"  command, a faster working environment is provided by converting two-dimensional drawings into blocks and sub-blocks.
To block 2D objects;
  • Click the Drawings/Modify/Make Block icon in the ribbon menu.
  • Select 2 dimensional objects to make block.
  • Press the right mouse button.
  • The 2-dimensional objects you choose will become blocks.
Drawing before using the make block command:
The drawing after using the make block command:
