Settings such as elevation, length, rotation angle and material selection of 3D text/text created with 3d text settings are adjusted.
3D Text Settings Location
Select the 3D text and click the right button of the mouse and click the Properties line from the menu that opens, and you can access the settings of the 3D text.
Extended Item Tab
Elevation The level of the object is entered from the floor base. |
Length It is the elongation length of the 2 dimensional section defined in the plan. |
Spherical coordinate horizontal It is the angle that the axis makes with the horizontal (x-axis). |
Spherical coordinate vertical It is the angle that the axis makes with the vertical (z-axis). |
Vectoral x / y / z
Values expressing the direction of the extension process in vector form. |
Local rotation x / y / z
They are the values that determine the angle made by the section to be wrapped around the main axis according to its local axis. |
Color Choose the color of the object from the color palette that opens when clicked. |
Line type The line type of the line of the 3D text that appears in the plan is selected from the list that opens when clicked. |
Material appearance
The material to be used on the top, bottom and other surfaces of 3D text is selected from the list. Surfaces are covered with the selected material and displayed as such in renderings. Texture length is entered into the world length. For example; If 1 is entered, the selected material texture is taken as 1 meter and covered on the relevant walls. The angle is the angle of the texture. Touch the U and V shifting. The motion value in the x and y plane is entered. With U and V mirroring, the texture is symmetrical with respect to the y and x plane. By selecting the single material option, the material selected in "Top material" is used on all surfaces of 3D text. |
Schematic drawing
Includes a schematic drawing and dimensions of the 3D text. |
3D preview
It is a 3-dimensional view of 3D text. You can rotate the image around itself by holding down the left mouse button and moving it. You can zoom in and out by holding the right mouse button and moving the mouse. |
Components Tab
Click the Add Building Component button.
In this dialog, click the folder related to the material from the list on the left. Choose the material you want to use.
In the usage section
Following are the lines that appear in the proportion list according to the extruded object and material size.
Extruded Object |
Measure |
Listed |
Explanation |
Constant |
Independent |
Length |
Independent |
Length |
It means that the length of the material will be found by multiplying the length measure found when defining the material and the length of the object. |
Area |
Independent |
It means that the area measure found while defining the material will be used exactly as the field value. |
Area |
By multiplying the area measure found while defining the material with the area of the roof, the area of the material will be found. |
Volume |
Independent |
It means that the volume measurement found when defining the material will be used exactly as the volume value. |
Volume |
It means that the volume measure found when defining the material will be multiplied by the object volume. |
Count |
Independent |
The number measure found while defining the material will be used exactly as the number value. |
Count |
