Loading Saved Reports
To reopen a previously saved report, first run the ideCAD Report program. The ideCAD Report program is the iderpt.exe file under the ideYAPI program folder. Double click to run it. With the Open command, the reports are opened again.
Location of the Open Command
You can access the ideCAD Report program under the File menu.
  • Click the Open line from here.
  • Select the report file you want to open from the Open Report File dialog that opens and click the Open button.
  • The selected report will open.
