Sweep Settings
With the General Sweep Settings command, the alignment type, elevation, material and drawing settings of the profile object can be accessed.
Location of the General Sweep Settings Command
You can access it under the 3D Geometric Objects title of the Ribbon menu, Facade tab .
General Tab
Alignment
The position of the sweep in the story is adjusted. If "story top" is checked, the profile object is placed on the ceiling of the story, if "story bottom" is marked, the profile object is placed on the floor of the story. If "User defined" is marked and the elevation is given, the sweep is drawn according to the floor of the story entered as high as the entered elevation.
Place sweep
The position of the sweep relative to the section is adjusted with the inner and outer options. If outer is marked, the sweep is drawn based on the outer edge of the section, if the inner is marked, based on the inner edge.
Color
Select the color of the sweep from the dialog that opens when clicked.
Material
Select the material (texture) of the surfaces of the sweep from the drop-down list for the solid model.
Texture length of the material used is entered into the texture world length. For example; If 1 is entered, the selected material texture width is taken as 1 unit and covered on the relevant walls. Considering that the texture is in the form of a square, the object surfaces are covered with 1x1 textures arranged side by side. It can be determined separately for each surface.
Invisible edge line type
Select the linetype of the background lines from the list. You can cover (invisible) any edge of the sweep. You may want to make the line types of the edges that you make invisible, different from other edges.
Project profiles
It is the list of profiles belonging to the sweep. The selected profile will be used in the enclosure. Profile preview is drawn on the right.
Schematic section
Includes the dimensioned drawing of the selected section.
3D preview
It is a 3-dimensional view of the sweep. You can rotate the image around itself by holding down the left mouse button and moving it. You can zoom in and out by holding the right mouse button and moving the mouse.
Components Tab
  • Click the Add Building Component button.
  • In this dialog, click the folder related to the material from the list on the left. Choose the material you want to use.
In the usage section
Following are the lines that appear in the proportion list according to the wall object and material size.
Sweep
Measure
Listed
Explanation
Constant
Independent
Length
Independent
Length
It means that the length of the material will be found by multiplying the length measure found when defining the material and the length of the sweep.
Area
Independent
It means that the area measure found while defining the material will be used exactly as the amount.
Outside area
It means that the area measure found while defining the material will be used by multiplying it with the sweep outside area.
Volume
Independent
The volume measure found when defining the material will be used exactly as the volume of the material.
Volume
It means that the volume measure found when defining the material will be used by multiplying the sweep volume.
Count
Independent
The count measure found while defining the material will be used exactly as the material number.
Count
It means that the number measure found when defining the material will be multiplied by the number of sweeps
Creating a Sweep
