Defining a Column-Column Connection (Built Up Column)
With the Column-Column Connection (Built Up Column) command, two columns are combined according to the given knitting type.
Location of Column-Column Connection (Built Up Column) Command
You can access it under the ribbon menu, Connection tab, Experimentals title.
  • From the Steel menu, click on the Experimentals/Column-Column Connection (Built Up Column) line.
  • In a 3D perspective view, click the first, then the second, of the columns to be joined.
  • Double-click the connecyion to change settings.
  • The built up column connection dialog will open.
Location of the Built Up Column Connection Dialog
Construction Tab
Distance
By selecting the option, patterns are determined by entering the plate distance values. The values ​​to be entered are shown in the schematic drawing.
Count
By checking the option, patterns are determined by entering the count. The values ​​to be entered are shown in the schematic drawing.
Connection
Welded or bolted types are selected for plate connection.
Alignment
Alignment of the plates according to the column is determined by choosing one of the middle or corner options.
Schematic drawing
Preview
Pattern Tab
Pattern
One of the listed pattern types is selected.
Edge type
One of the listed edge types is selected.
Element alignment to first column
Element alignment to the first column is determined by checking the horizontal or perpendicular option.
Preview
Parameters Tab
Use plate
If the option is selected, it is determined by entering the plate values. The values ​​to be entered are shown in the schematic drawing.
Material
The material is selected for the created sheet.
Use section
By selecting the option, one of the ready profiles is selected from the lists as a plate. By clicking on the Load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list. The selected profile can be rotated if desired.
Schematic drawing
Preview
Welds Tab
This tab appears when the welded is marked in construction tab.
Welds
Weld electrode
Schematic drawing
Preview
Bolts Tab
This tab appears when the bolted is marked in construction tab..
Horizontal arrangement
Group 1
Distance values ​​of bolts are entered. The values ​​to be entered are shown in the schematic drawing.
Bolt properties
Schematic drawing
Preview
Design Data Tab
