Breadcrumbs
Default Keyboard Shortcut
Keyboard and mouse are used for command and information input in the ideCAD. The keyboard and mouse can be used together or separately.
Keys with special functions defined on the keyboard are given in the table below.
Command Name
Shortcut
Enter
Runs the command. It has functions in various command stages.
Esc
Exits the found command.
Home
Perspective returns the image to the origin on the screen.
Page Down
Scrolls down the page in reports. Shifts the viewpoint down in flight mode in the perspective view.
Page Up
Scrolls the page up in reports. Shifts the viewpoint upwards in flight mode in the perspective view.
Space
Moves the cursor to horizontal, vertical, and free axis drawing positions on axes. It changes the offset in commands such as wall, column, beam, curtain. Omits a name in object naming. The library changes the insertion point in commands such as ladder.
The shortcut keys defined by default in the ideCAD are given in the table below.
Command Name
Shortcut
Open
Ctrl + O
Angle (Coordinate Box)
A
Aksonometrik
F7
Analysis Design
F9
Plot
Ctrl + P
Nearest Point
F6
Undo
Ctrl + Z
Select All
Ctrl + A
Deselect All
Ctrl + D
Draw in Fast Mode
Ctrl + H
Redo
Ctrl + Y
Save
Ctrl + S
Copy
Ctrl + C
L (Coordinate Box)
L
Structural Design Mode/ Architectural Mode
Shift + Tab
Find Entity
Ctrl + F
Entity Properties
Ctrl + E
Select in all Stories
Ctrl + B
Midpoint
F5
Previous window
Alt + Down
Get selection
Ctrl + 2
Set selection
Ctrl + 1
Delete
Delete
Next window
Alt + Up
Fullscreen
F8
X (Coordinate Box)
X
Y (Coordinate Box)
Y
Paste
Ctrl + V
Help
F1
New Project
Ctrl + N
Zoom Window
Ctrl + W
Zoom Drawing
Ctrl + X
Zoom Out (-)
Zoom In (+)
If you want, you can define the shortcuts you want to the commands by customizing them.
