Rigid and semi-rigid diaphram conditions should be choosen by user according to irregularities defined in Codes.
Analysis is done automatically according to finite element method.
Required strength is designed to analyse with Load Factors and Combinations
International Design Codes
ACI 318-19 : Two-Way Slab Required Strength per ACI 318-19 with ideCAD
TSC 2018 : Punching Shear Stress at Critical Section (7.11.8)
Symbols in ACI 318-19
Required strength is designed to analyse with Load Factors and Combinations. Analysis is done automatically according to finite element method. Rigid and semi-rigid diaphram conditions should be choosen by user according to Codes.
