Create the Columns
In this section, create the base story columns.
Previous steps have been followed in the project file named Create the Columns. You can download the file and follow the steps given in this title on the project.
Create the Columns.cde
  • Click on the column command. From the column toolbar, select the corner aligned column option.
  • Enter 40cm/30cm as the value in the toolbar.
  • Click on A-1 axis intersection. Rotate the column so that the 40 cm side of the column is on axis A and click the left button to place.
  • Click on the A-2 axis intersection. Take the symmetry of the column with the spacebar.
  • Rotate the column so that the 40 cm side of the column is on axis A and place it.
  • Click on the A-3 axis intersection. Rotate the column so that the 40 cm side of the column is on the axis 3 and place it.
  • Click on the B-4 axis intersection. Rotate the column so that the 40 cm side of the column is on the axis 4 and place it.
  • Click on the B-3 axis intersection. Rotate the column so that the 40 cm side of the column is on the axis 3 and place it.
  • Click on the B-2 axis intersection. Take the symmetry of the column with the spacebar.
  • Rotate the column so that the 40 cm side of the column is on the axis B and place it.
  • Click on the B-1 axis intersection. Take the symmetry of the column with the spacebar.
  • Rotate the column so that the 40 cm side of the column is on the axis 1 and place it.
  • Click on the C-1 axis intersection. Rotate the column so that the 40 cm side of the column is on the axis 1 and place it.
  • Click on the D-1 axis intersection. Rotate the column so that the 40 cm side of the column is on the axis 1 and place it.
  • Click on the C-2 axis intersection. Take the symmetry of the column with the spacebar.
  • Rotate the column so that the 40 cm side of the column is on the axis 2 and place it.
  • Click on the D-2 axis intersection. Take the symmetry of the column with the spacebar.
  • Click on the D-3 axis intersection. Take the symmetry of the column with the spacebar.
  • Rotate the column so that the 40 cm side of the column is on the axis 3 and place it.
  • Click on the D-4 axis intersection. Take the symmetry of the column with the spacebar.
  • Rotate so that the 40 cm side of the column is on the axis 4 and place it.
  • Click on the C-4 axis intersection. Take the symmetry of the column with the spacebar.
  • Press the Esc key on the keyboard to exit the command.
  • Base story columns are completed.
Next Tutorial
Create the Zones
