Single footing, strip footing and mat foundations are designed automatically according to Codes
International Design Codes
ACI 318-19 : Shallow Foundation per ACI 318-19 with ideCAD
TSC 2018 :
Notation in ACI 318-19
Es = modulus of elasticity of reinforcement, psi
β = ratio of long to short dimentions; clear spans for two-way slabs, sides of column, concentrated load or reaction area; or sides of a footing
γs = factor used to determine the portion of reinforcement located in center band of footing
