Defining Double Angle Connection
With the Double Angle Connection command, column-beam connection is defined.
Location of the Double Angle Connection Command
  • From the Connection menu, click the Double Angle Connection icon.
  • The double angle connection settings dialog will open.
Location of the Double Angle Connection Settings Dialog
Type and Placement Tab
Connection to support
Bolted or welded connection types are selected for the support connection.
Connection to beam
Bolted or welded connection types are selected for the beam connection.
Orientation
One of the angled or straight options is chosen for the connection orientation.
Placement
Placement values ​​are entered. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Connection and placement values ​​are shown on the schematic drawing.
Preview
Angle Tab
The geometry of the angle used is given or one of the L profiles in the library can be used as a connection element with the Use Section option. If you check the plate geometry option, enter the plate dimensions according to the schematic representation.
Define plate geometry
If the option is selected, it is determined by entering the angle values. The values ​​to be entered are shown in the schematic drawing.
Use section
By selecting the option, one of the ready-made L profiles is selected from the list as an angle bracket. By clicking on the load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list.
Length
Angle length value is entered.
Schematic drawing
Preview
Top/Bottom Notch Tabs
Notch
If the option is selected, notching is done according to the entered values. The values ​​to be entered are shown in the schematic drawing.
Left flange cut
If the option is selected, left header cutting is made according to the entered values. The values ​​to be entered are shown in the schematic drawing.
Right flange cut
If the option is selected, right header cutting is made according to the entered values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Support Bolts Tabs
The properties of the bolts that connect the plate to the beam or column are adjusted.
Horizontal arrangement
Horizontal arrangement settings (number of horizontal bolt columns, distance values ​​..) of support bolts are entered. The values ​​to be entered are shown in the schematic drawing.
Group 1
Support bolts settings (number of lines, distance values ​​..) are entered. The values ​​to be entered are shown in the schematic drawing.
Bolt properties
Schematic drawing
Preview
Beam Bolts Tabs
Horizontal placement
Horizontal placement settings (number of horizontal bolt columns, distance values ​​..) of beam bolts are entered. The values ​​to be entered are shown in the schematic drawing.
Group 1
Beam bolts settings (number of lines, distance values ​​..) are entered. The values ​​to be entered are shown in the schematic drawing.
Bolt properties
Schematic drawing
Preview
Welds Tab
In the Welds tab, the weld properties of the connections given in the schematic representation are set.
Welds
Weld electrode
The strengths of the weld electrodes are defined in the design inputs. The strength of the main element in the weld joint is controlled under the condition that it has less strength than the weld strength.
To create the weld electrode, provide the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New".
Schematic drawing
Preview
Design Data Tab
