Beam Drawings
With the Beam Drawings command, the beam detail drawings of the project are prepared.
Location of the Beam Drawings Command
  • Click the Beam Drawingws icon.
  • The drawing properties dialog will open.
  • Make the edits you want and click the OK button.
  • The beams of the working story will be automatically designed according to the scale and paper size specified in the drawing settings. One or more beam drawing windows can be created according to the fit in the paper. The relevant window can be selected from the list under the Window menu.
In beam drawings, the beams are arranged as blocks with rebars and dimension lines. Especially since the moving work can be done a lot, the blocks facilitate the moving process. You can split the blocks into sub-blocks with the explode. In the sub-blocks, again, the object can be divided into lines and writings with explode.
General Tab
Specifications - Colors
Background color
Rebar text
Sets the color of the rebar text. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar line
Sets the color of the rebar line. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar ID text
Adjusts the color of the rebar ID text. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar ID circle
Adjusts the color of the rebar ID circle. When the color box is clicked, the appropriate color is selected from the window that opens.
Dimension text
Sets the dimension text color. When the color box is clicked, the appropriate color is selected from the window that opens.
Dimension line
Sets the dimension line color. When the color box is clicked, the appropriate color is selected from the window that opens.
Object ID
Object body
Axis line color
Sets the color of the axis line. When the color box is clicked, the appropriate color is selected from the window that opens.
Axis circle color
Sets the color of the axis circle. When the color box is clicked, the appropriate color is selected from the window that opens.
Axis text color
Adjusts the text color of the axis. When the color box is clicked, the appropriate color is selected from the window that opens.
Section color
Sets the section color. When the color box is clicked, the appropriate color is selected from the window that opens.
Specifications - Appearance
Rebar text
The height of the rebar text is entered.
Rebar levels displacement
The distance between the two rebar texts is entered.
Dimension text
Object ID
Rebar font
The rebar font is selected.
Dimension font
Dimension font is selected.
Object ID font
Object ID font is selected.
Axis label radius
The radius of the axis label is entered.
Axis line type
Axis line type is selected. Clicking the down arrow buttons to the right of the boxes opens the list of line types. From this list, the desired line type is selected by clicking with the left mouse button.
Dimension marker type
The dimension marker type is selected.
Paper Tab
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Advanced Tab
Draw rebar ID’s
If checked, rebar ID’s are shown in the drawings. If not checked, it will not be displayed.
Arrange blocks by name
Generate elevations
If checked, elevations are shown in the drawings. If not checked, it will not be displayed.
Generate rebar descriptions
If checked, the rebar definitions are shown in the drawings. If not checked, it will not be displayed.
Generate auxillary bar dimensions
If marked, the lengths of auxillary bars are measured in the drawings.
Generate overlapping bar dimensions
If it is marked, the lengths of the overlapping bars in the drawings are measured.
Split long beams for fitting to paper
If marked, long beams that exceed the layout size in the drawings are divided.
Draw stirrup counts
If checked, stirrup counts are written in the drawings.
Min. distance between blocks
Distance between lines
Table Settings
Table contour lines
Sets the color of the table contour lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Table lines
Sets the color of the table lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Table header texts
Sets the color of the table header texts. When the color box is clicked, the appropriate color is selected from the window that opens.
Text
Steel drawing
Sets the color of the steel drawing. When the color box is clicked, the appropriate color is selected from the window that opens.
Create steel bar table
If marked, the rebars are divided into types and a table is created indicating the number, diameter, length, type and weight, and the rebar quantity is shown in the drawing.
Draw steel bending table
If checked, the rebars are divided into bending types and a table is created indicating the number, diameter, length and type, and the bend is shown in the drawing.
Draw reinforcement table
If checked, the reinforcement table is created and shown in the drawing.
Draw object names table
If checked, the object names table is created and shown in the drawing.
Group steels according to layouts
If checked, the steels are grouped according to the layout and shown in the drawing.
Similar Stories Tab
No and Name
Story numbers and names are listed
Similar with
Identified as similar and base story from the list.
When arranging similar story beam expansions, the most unsuitable main story should be chosen. Otherwise, the equipment that is not on the main story but on the upper stories will not be visible in the drawings. The main story should be determined by checking the beam reinforcements from the concrete dialogs or reports.
Annotations Tab
Defined annotations are listed.
Preview
There is a preview of the annotation selected from the list.
Annotation width
Annotation width is determined.
Layout number
The layout number is determined.
Create New
The new annotation is created.
Edit
The annotation is edited.
Delete
The annotation is deleted.
Don’t add annotation block to the layout
If it is checked, annotation will not be added to the layouts.
Rib Drawings
