Transforming Polygon to Plate Section
With the Polygon to Plate Section command, a closed area created by a line is converted to a plate section. With this method, plate sections are defined in the desired forms.
Location of Polygon to Plate Section Command
  • Create a closed area with the line.
  • Click the command polygon to plate section.
  • The Section Settings dialog will open. Set your section name and material.
  • The section you define will be listed under the Sections row in the Structure Tree view .
Structure tree before the sheet section is formed
Creating a closed area with a line
Selecting the area to be transformed into a plate section
Editing the settings
Creation of the plate section and adding it to the structure tree
