Defining a Seating Support Connection
With the Seating Support Connection command, column-beam connection is defined.
Location of the Seating Support Connection Command
  • From the Connection menu, click on the Seating Support Connection icon.
  • The seating support connection settings dialog will open.
Location of the Seating Support Connection Settings Dialog
Geometry and Type Tab
Type
One of the connection types is selected from the list.
Plate dimensions
Plate dimensons are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Rollers
Rollers dimensions are determined by entering values.
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld connection is controlled under the condition that it has less strength than the weld strength.
To create the welding electrode, provide the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New".
Schematic drawing
Preview
Cradle Tab
It becomes active when the crane type is selected in the type section.
Dimensions
Crane dimensions are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Connection and crane values ​​are shown on the schematic drawing.
Preview
Bolts Tab
It becomes active when bolted type is selected in the type section.
Horizontal arrangement
Group 1
Bolt properties
Schematic drawing
Preview
Brackets Tab
It becomes active when bracket type is selected in the type section.
Bracket dimensions
Bracket dimensions are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Design Data Tab
Defining a Stub
