Design of 8 Bolts Stiffened End Plate Connection
Connection Geometry
GEOMETRY CHECKS
Bolt Spacing
smin ≥ 3d
ÇYTHYEDY 13.3.6
s
90 mm
d
24 mm
s =90 mm > smin = 3*24=72 mm
Horizontal Edge Distance
Leh ≥ Le- min
ÇYTHYEDY 13.3.7
Leh
42.5 mm
Le- min
32 mm
Table 13.9
Vertical Edge Distance
Lev ≥ Le- min
ÇYTHYEDY 13.3.7
Lev
35 mm
Le- min
32 mm
Table 13.9
Beam Web to End Plate Weld Size
a ≥ amin
a
5 mm
amin
3.5 mm
Table 13.4
Stiffener to Beam Web Weld Size
a ≥ amin
a
9 mm
amin
4 mm
Table 13.4
Stiffener to End Plate Weld Size
a ≥ amin
a
9 mm
amin
4 mm
Table 13.4
a ≥ amin
a
8 mm
amin
4 mm
Table 13.4
a ≥ amin
a
8 mm
amin
4 mm
Table 13.4
Prequalification Limits (TBDY Table 9B.1)
Beam span/Beam depth
8000mm /450mm=17.78
≥7.0
End plate thickness, tp
25mm
18≤t p ≤65
End plate width, bp
215mm
B 215≤ P ≤ 400
Horizontal distance between bolts, g
130mm
125≤g≤155
pfi
40mm
40≤p fi ≤50
pfo
40mm
40≤p fi ≤50
pb
90mm
90≤p b ≤100
Beam depth, db
450mm
450≤ d b ≤ 950
Beam flange thickness, tbf
14.6mm
14≤t bf ≤35
Column depth
450
≤ 920mm
Bolt grade
10.9
8.8 - 10.9
Min yield stress of end plate material
275 MPa
235 /275/355 MPa
Flange plate weld
CJP
CJP
Strength Checks
Bolt Diameter
Muc
810.184 kNm
AISC 358-16 (6.8-4)
Ft
750000 kN/m2
h1
h2
h3
h4
db
Required
Available
Ratio
Check
20.946 mm
24 mm
0.873
End Plate Thickness
Muc
810.184 kNm
AISC 358-16 (6.8-5)
Fyp
275000 kN/m2
s
Yp
Yp
6228.788
tp
Required
Available
Ratio
Check
22.913 mm
25 mm
0.917
End Plate Stiffener Thickness
tbw
9.4 mm
AISC 358-16 (6.8-9)
Fyb
275000 kN/m2
Fys
275000 kN/m2
ts
15 mm
Required
Available
Ratio
Check
9.4 mm
15 mm
0.627
End Plate Stiffener Local Buckling
hs
210 mm
AISC 358-16 (6.8-10)
ts
15 mm
E
205939650 kN/m2
Fys
275000 kN/m2
Required
Available
Ratio
Check
11 mm
15.102 mm
0.728
Stiffener to Beam Flange Weld Size
Fys
275000 kN/m2
AISC DG 4-2nd
3.2.10
ts
15 mm
Fe
480000 kN/m2
w
Required
Available
Ratio
Check
8.103 mm
12.73 mm
0.637
Fys
275000 kN/m2
AISC DG 4-2nd
3.2.10
ts
15 mm
Fe
480000 kN/m2
w
Required
Available
Ratio
Check
7.938 mm
8.487 mm
0.935
Bolt Shear at Support
Ab
Fn
Rn
ΦRn
Required
Available
Ratio
Check
265.11 kN
1465.74 kN
0.181
Bolt Bearing on End Plate
dh
24+2=26 mm
Lc,edge
Rn
ÇYTHYEDY 13.3.13
Eq. 13.14a and 13.14b
Rn-edge
Lc,spacing1
Rn-spacing1
Lc,spacing2
Rn-spacing2
Rn
ΦRn
Required
Available
Ratio
Check
265.11 kN
3854.52 kN
0.069
Bolt Bearing on Column Flange
dh
24+2=26 mm
Rn
ÇYTHYEDY 13.3.13
Rn-edge
Lc,spacing1
Rn-spacing1
Lc,spacing2
Rn-spacing2
Rn
ΦRn
Required
Available
Ratio
Check
265.11 kN
5499.187
0.048
Fyp
275000 kN/m2
AISC 358-16
(6.7.6)3
tbw
9.4 mm
Fe
480000 kN/m2
w
Required
Available
Ratio
Check
5.078 mm
7.072 mm
0.718
Column Flange Thickness
Muc
810.184 kNm
AISC 358-16 (6.8-13)
Fyc
355000 kN/m2
s
Yc
Yc
tcf
Required
Available
Ratio
Check
17.954 mm
26 mm
0.691
Panel Zone Thickness
tmin≥u/180
TBDY 2018 9.3.4.2b
tmin=tw
14 mm
tw
14 mm
u
1637.6 mm
Required
Available
Ratio
Check
9.098 mm
14 mm
0.65
