Shear Wall Reinforcement Limits.
  • Longitudinal and Transverse reinforcement limits are controlled automatically.
International Design Codes
ACI 318-19 : Shear Wall Reinforcement Limits per ACI 318-19 with ideCAD
TSC 2018 : Shearwall web Reinforcement Limits
Notation in ACI 318-19
Acv = gross area of concrete section bounded by web thickness and length of section in the direction of shear force considered in the case of walls, and gross area of concrete section in the case of diaphrams. Gross area is total area of defined section minus area of any openings, in.2
αc = coefficient defining the relative contribution of concrete strength to nominal wall shear strength
ϕ = strength reduction factor
λ = modification factor to reflect the reduced mechanical properties of lightweight concrete relative to normal weight concrete of the same compressive strength
ρl = ratio of area of distributed longitudinal reinforcement to gross concrete area perpendicular to that reinforcement
ρt = ratio of area of distributed transverse reinforcement to gross concrete area perpendicular to that reinforcement
