Vault Truss
With the Vault command, the vault truss type which is one of the prepared truss types, is drawn quickly. Truss heights are adjusted from the truss settings.
Vault Truss Schematic Drawing:
Location of the Vault Command
  • Click on the vault command.
  • In the Heights tab , enter the heights h4 for vault.
Entering 150 cm for h4 in the height tab of the truss settings
Double Vault Truss
