Create a Project
In this section, within the scope of building information modeling, you can open a new project and add a new floor.
To open a new project;
  • Click on the new project icon.
  • In the new project dialog that opens, select start using new project wizard and click the open button.
  • The Country & General dialog will open. Select the Türkiye for the country, metric for the unit, and white background for the project colors.
  • Click the Finish button.
  • A new project file will be opened.
In the project you have just opened, the base story will be defined. To add the 1st story to the project;
  • Click on the Home menu Story Settings icon.
  • The Stories dialog will open.
  • Change it if the default height is not 300 cm.
  • Click the add above button.
  • The first story with a height of 300 cm will be defined.
  • When you click the OK button, the story definition process will be completed.
Next Tutorial
Create Lot Lines
