Flexural Reinforcement Detailing (BRD)
  • Longitudinal reinforcement detailing is applied automatically in accordance with Codes.
  • Longitudinal reinforcement detailing is applied according to Codes in earthquake resistant structure beams.
International Design Codes
ACI 318-19 : Flexural Reinforcement (BRD) per ACI 318-19 with ideCAD
TSC 2018 : Longitudinal Reinforcement Detailing for Beams.
Notation in ACI 318-19
la = additional embedment length beyond centerline of support or point of inflection, in.
βb = ratio of area of reinfocement cut off to total area of tension reinforcement at section.
ϕ = strength reduction factor
