Adding Company Picture to Reports
It is possible to print the company picture on the reports. The company picture will be displayed in the upper right corner of the report pages.
The company picture can be selected in the select reports dialog before the report is prepared , or can be selected in the report program after receiving the report.
Location of Company Picture Command
You can access the Company Picture command from the edit menu .
Within the report program:
  • Get a report.
  • Click the Company Picture line under the Edit menu in the report program .
  • The insert picture dialog will open. In this dialog, select the company picture you saved in any image format.
  • Click the Open button to close the dialog.
  • After this stage, your company picture will also be seen in the upper right corner of each report.
Report pages without company picture attached
Report pages with company picture attached
