Assembly Drawings
The Assembly Drawings command is used to prepare assembly drawings.
Location of the Assembly Drawings Command
  • Click the Assembly Drawings icon.
  • Assembly drawings will be created.
  • Before creating the drawings, you can access the Steel Drawing Settings dialog by clicking the settings button from the steel drawings dialog . From this dialog, layout settings, scales, fonts, etc. You can access parameters related to steel drawings.
Sample assembly drawing
