Panel Hydrostatic Load
Water pressurized soil load is added to the shearwalls with the Panel Hydrostatic Load command.
Location of Panel Hydrostatic Load Command
You can access it from the Add Load heading in the Modify tab in the Ribbon menu .
  • Click on the Panel Hydrostatic Load icon.
  • Click the shearwall.
  • The Hydrostatic Load dialog will open.
  • Define the values ​​by following the lines in the dialog.
Hydrostatic Load Dialog
Water level (global)
The water level elevation is entered for the water load to be added.
Reverse load direction
Changes the direction of the defined load.
Edit Entity Loads
