Creating Railing over Objects
The Railing over Objects command, which is used to draw the railing by taking the slope of the object defined on it , is applied to define a railing on objects such as stairs, spaces, curved walls. It automatically takes the elevation of the object defined on the railing and adapts to the elevation of the relevant object.
Location of Railing Over Objects
You can access it under the Ribbon menu Home tab, Entities title.
  • Define a stair.
  • Click the Railing Over Object icon in the ribbon menu .
  • The railing toolbar will appear on the screen, however, another auxiliary toolbar called Path Segments will be opened.
  • There are icons in the Path Segments toolbar that allow you to draw the railing line in a straight, circular and curved form.
  • Click the appropriate icon (the default straight line icon is selected).
  • Move the cursor to the first flight of the stair and click a point.
  • The select entity dialog will open. Select the object you want to place from the list and click the OK button.
  • At this stage, if you press the spacebar on the keyboard, you will get the mirror of the railing with respect to its axis.
  • Continue defining the next points on the other flights of the stair. Make an entity selection at each new point.
  • When you end the command by pressing the right mouse button, the railing will be formed on the stairs in accordance with the stairs.
Before creating a railing over objects
Clicking on the first step for the first point of the railing
Choosing the object to place the railing
Clicking on the second step
Clicking on all steps for the first stair flight
Clicking on the inner corners of the landing
Clicking all steps for the second stair flight
Completing the railing by clicking the right mouse button
