Boundary Elements of Special Structural Walls.
  • Boundary Elements of Special Structural Wall requirements are met automatically
International Design Codes
ACI 318-19 : Boundary Elements of Special Structural Walls per ACI 318-19 with ideCAD
TSC 2018 : Boundary Regions Reinforcement Detiling Conditions
Notation in ACI 318-19
Ach = cross-sectional area of a member measured to the outside edges of transverse reinforcement, in.2
Acv = gross area of concrete section bounded by web thickness and length of section in the direction of shear force considered in the case of walls, and gross area of concrete section in the case of diaphrams. Gross area is total area of defined section minus area of any openings, in.2
b = width of compression face of member, in.
hu = laterally unsupported height at extreme compression fiber of wall or wall pier, in. equivalent to lu for compression members
hwcs = height of entire structural wall above the critical section for flexural and axial loads, in.
hx =maximum center-to-center spacing of longitudinal bars laterally supported by corners of crossties or hoop legs around the perimeter of a column or wall boundary element, in.
Ve = design shear force for load combinations including earthquake effects, lb
ρs = ratio of volume of spiral reinforcement to total volume of core confined by the spiral, measured out-to-out of spirals
δc = wall displacement capacity at top of wall, in.
δu = design displacement, in.
