Edit Entity Loads
With the Edit entity load command, the contents of previously defined loads are changed.
Location of Edit Entity Load Command
You can access it from the Add Load heading in the Modify tab in the ribbon menu .
  • Click the Edit Entity Load line.
  • Click on the element you previously defined the load on.
  • The Edit Loads dialog will appear.
Edit Loads Dialog
Load info
Summary information of defined loads appears.
Entity list
The name of the element for which the load is defined appears.
Properties
Opens the contents of the payload that appears on the line with the cursor.
Delete
Deletes the payload that appears on the line with the cursor.
Delete all
Deletes all loads in the list.
