ideYAPI BIM Knowledgebase Get Started Current: Tutorial Videos Tutorial Videos Part 1. Create a Project Part 2. Create Lot Lines Part 3. Create the Axes Part 4. Create Walls Part 5. Create the Columns Part 6. Create the Zones Part 7. Create the Beams Part 8. Create the Slabs Part 9. Place Doors Part 10. Place the Windows Part 11. Create the Curtain Wall Part 12. Copy Base Story to Upper Part 13. Create the Upper Story Walls Part 14. Create the Upper Story Zones Part 15. Create the Upper Story Beams Part 16. Create the Upper Story Slabs Part 17. Place the Upper Story Doors Part 18. Create the Stairs and Railings Part 19. Create the Patio Railings Part 20. Create the Steel Columns Part 21. Create the Steel Beams Part 22. Create the Steel Purlins Part 23. Create the Sheetings Part 24. Create the Roof Part 25. Create the Gutter and the Rainwater Pipe Part 26. Create the Raft Foundation Part 27. Create the Terrain Part 28. Create the Swimming Pool Part 29. Create the Facade Elements Part 30. Place the Furnishings Part 31. Create the Horizontal Plan Section Part 32. Create the Section and Elevation Views Part 33. Add Dimensions Part 34. Create the Layout Part 35. Create the Render Part 36. Create the Animation Part 37. Collaborate The ideCAD One Model Part 38. Get the ideYAPI Building Information Model Part 39. Get the IFC Building Information Model Part 40. Get the 2D / 3D Drawings Part 41. Create a New Structural Building Information Model Part 42. Examine the Structural System Part 43. Use the Wizard for Analysis Settings Part 44. Optimize the Structural System Part 45. Check Geometry and Failure Part 46. Fix the Failures Part 47. Examine the Analysis Model Part 48. Examine the Load Model Part 49. Analysis and Design Part 50. Review Analysis Results Part 51. Review Concrete Design Part 52. Review Steel Design Part 53. Modelling Steel Connections - 1 Part 54. Modelling Steel Connections - 2 Part 55. Generate Select Reports Part 56. Generate Concrete Design Reports Part 57. Generate Steel Design Reports Part 58. Create Concrete Drawings Part 59. Create Steel Drawings ×
