Skip to main content
Skip table of contents
Well Foundation Drawings
Drawings of the well foundation can be prepared with the Well Foundation Drawings command.
Location of the Well Foundation Drawings Command
  • Click on the Well Foundation Drawings icon.
  • The drawing properties dialog will open. If there is a different situation in this dialog, change the parameters related to the drawing.
  • When you click the OK button, the well foundation drawing will be created.
General Tab
Specifications - General
Background color
Object color
Sets the object color. When the color box is clicked, the appropriate color is selected from the window that opens.
Name color
Sets the name color. When the color box is clicked, the appropriate color is selected from the window that opens.
Name height
Name height is entered.
Specifications - Dimensions
Line color
Sets the measure line color. When the color box is clicked, the appropriate color is selected from the window that opens.
Text color
Text height
Size text height is entered.
Specifications - Fonts
Name font
Name font is selected.
Length font
The font of the length fonts is selected.
Diameter font
Diameter font is selected.
Specifications - Rebar
Line color
Sets the color of rebar lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Length text color
Sets the color of the length text. When the color box is clicked, the appropriate color is selected from the window that opens.
Diameter text color
Sets the color of the diameter text. When the color box is clicked, the appropriate color is selected from the window that opens.
ID text color
Sets the color of the ID text. When the color box is clicked, the appropriate color is selected from the window that opens.
ID circle color
ID sets the color of the circle. When the color box is clicked, the appropriate color is selected from the window that opens.
Length text height
Text height is entered.
Diameter text height
Diameter text height is entered.
ID text height
ID text height is entered.
Specifications - Hatches
Concrete hatch
It is the hatch type that is valid for concrete. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the lookup table in this dialog.
Soil hatch
It is the hatch type that is valid for the soil. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the lookup table in this dialog.
Ground hatch
It is the hatch type that is valid for the ground. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the look-up table in this dialog.
Advanced Tab
Scale (1/X)
In what scale the drawings will be drawn, that value is entered.
Paper height
Standard paper sizes
Vertical/Horizontal use
Layout border color
You can select the layout border color from the color palette that appears when you click it. If clicked together with the Shift key, the pen thickness of the relevant color can be adjusted. The pen thickness value entered here is only used in inkjet printers.
Detail border color
You can select the detail border color from the color palette that appears on the screen when you click it. If clicked together with the Shift key, the pen thickness of the relevant color can be adjusted. The pen thickness value entered here is only used in inkjet printers.
Draw steel bar table
If checked, steel bar tables are added to the drawing.
Border color
Sets the color of the border lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Headers color
Sets the table header color. When the color box is clicked, the appropriate color is selected from the window that opens.
Text color
Sets the color of text. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar color
Sets the color of the rebar. When the color box is clicked, the appropriate color is selected from the window that opens.
Stair Drawings
JavaScript errors detected
