Skip to main content
Skip table of contents
Import/Export Problems
With the import and export options in ideCAD, files with different extensions (ifc, dwg, dxf, etc.) prepared in different programs are imported into the project, project studies are saved as files with different extensions (ifc, dwg, obj, pdf, etc.) and shared with other programs. Problems that may occur during import and export operations and possible solutions are listed under this heading.
JavaScript errors detected
