language: "en"
# Beam Reinforcement Detailing per ACI 318-19 with ideCAD
**How does ideCAD control beam reinforcement detailing according to ACI 318-19?**
* Reinforcement detailing is applied automatically in accordance with **ACI 9.7**.
* Covers of reinforced concrete elements are defined by user.
![:check_mark:](https://help.idecad.com/__attachments/a_3b4c5130f57d840d621c27c109903a793c637bdfa994d2d13dc978cfed9f5cf2/atlassian-check_mark?cb=a10212e1c1021c5194f7535b6843f955)
**Download ideCAD for ACI 318-19**
[**Get Started for FREE Structural Engineering Software**](https://d1ks2zzwb2c5zc.cloudfront.net/ideCAD_Structural11.18TrialSetup9vBg.exe)
**Notation**
***d*** ~***b***~**=** Nominal diameter of bar, wire, or prestressing strand, in.
***f*** ~***c***~^***'***^***=*** specified compressive strength of concrete, psi
***√fc'*** ***=*** square root of specified compressive strength of concrete, psi
**f** ~**y**~ **=** specified yield strength of nonprestressed reinforcement,psi
**K** ~**tr**~**=** transverse reinforcement index, in.
***l*** ~**d**~**=** development length in tension of deformed bar, deformed wire, plain and deformed welded wire reinforcement, or pretensioned strand, in.
**s =** center-to-center spacing of items, such as longitudinal reinforcement, transverse reinforcement, tendons, or anchors, in.
**ψ** ~**e**~**=** factor used to modify development length based on reinforcement coating
**ψ** ~**g**~**=** factor used to modify development length based on grade of reinforcement
**ψ** ~**s**~**=** factor used to modify development length based on reinforcement size
**ψ** ~**t**~**=** factor used to modify development length for casting location in tension
**λ =**modification factor to reflect the reduced mechanical properties of lightweight concrete relative to normalweight concrete of the same compressive strength
Concrete cover for reinforcement should be in accordance with **ACI Table 20.5.1.3.1**. The concrete cover is measured to the outer edge of ties, stirrups, or spirals if transverse reinforcement encloses the main bars.
|                **Concrete exposure**                |        **Member**        |                    **Reinforcement**                     | **Specified cover, in.** |
| Cast against and permanently in contact with ground | All                      | All                                                      | 3                        |
| Exposed to weather or in contact with ground        | All                      | #6 through #18 bars                                      | 2                        |
| Exposed to weather or in contact with ground        | All                      | #5 bar and smaller                                       | 1-1/2                    |
| Not exposed to weather or in contact with ground    | Slabs, joints, and walls | #14 and #18 bars                                         | 1-1/2                    |
| Not exposed to weather or in contact with ground    | Slabs, joints, and walls | #11 bar and smaller                                      | 3/4                      |
| Not exposed to weather or in contact with ground    | Beams, colums, pedestals | Primary reinforcement, stirrups, ties, spirals and hoops | 1-1/2                    |
*Cover* or *specified concrete* is defined as the distance between the outermost surface of embedded reinforcement and the closest outer surface of the concrete.
Development lengths of concrete beam reinforcement should be in accordance with [Development of Reinforcement per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/development-of-reinforcement.md) title. In this case, for deformed bars or deformed wires, ***l*** ~***d***~ is calculated in accordance with **ACI Table 25.4.2.3.** Other conditions are described in the [same](https://help.idecad.com/ideCAD/development-of-reinforcement.md) title.
Splices of deformed reinforcement should be in accordance with [Splices per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/splices.md) title.
Transverse reinforcement is provided such that ***K*** ~***tr***~, along with development and splice lengths of longitudinal bars with ***f*** ~***y***~***≥ 80,000*** psi. The minimum value of ***K*** ~***tr***~ is ***0.5d*** ~***b***~. ([Development of Reinforcement per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/development-of-reinforcement.md))
Minimum reinforcement spacing ***s*** is determined according to [Minimum Spacing of Reinforcement per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/minimum-spacing-of-reinforcement.md) title.
* [Flexural Reinforcement (BRD) per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/flexural-reinforcement-brd.md)
* [Transverse Reinforcement (BRD) per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/transverse-reinforcement-brd.md)
## **Download ideCAD for ACI 318-19**
**Next Topic**
**Related Topics**
* [Beam Stability per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/beam-stability.md)
* [Beam Design Limits per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/beam-design-limits.md)
* [Beam Required and Design Strength per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/beam-required-and-design-strength.md)
* [Beam Reinforcement Limits per ACI 318-19 with ideCAD](https://help.idecad.com/ideCAD/beam-reinforcement-limits.md)
