Skip to main content
Skip table of contents
Truss Drawing
The Truss Drawing command is used to prepare the truss drawings.
Location of the Truss Drawing Command
  • Click on the Truss Drawings icon.
  • Scissors drawings will be created.
  • Before creating the drawings, you can access the Steel Drawing Settings dialog by clicking the settings button from the steel drawings dialog . From this dialog, layout settings, scales, fonts, etc. You can access parameters related to steel drawings.
Sample truss drawing
JavaScript errors detected
