Skip to main content
Skip table of contents
Stair Drawings
Drawings of the stairs, whose calculation axes have been defined and analyzed, can be prepared with the Stair Drawings command.
Location of the Stair Drawings Command
  • Click the Stair Drawings row.
  • The drawing properties dialog will open. If there is a different situation in this dialog, change the parameters related to the drawing.
  • When you click the OK button, the stair drawing will be created.
General Tab
Specifications - Colors
Steel text
Steel line
Steel ID text
Steel ID circle
Total reinforcement length
Dimension text
Dimension line
Object ID
Object body
Axis ID
Axis
Adjusts the color of the axis. When the color box is clicked, the appropriate color is selected from the window that opens.
Specifications - Heights
Steel text
Steel ID
Steel - text distance
Steel levels displacement
Dimension text
Dimension - text distance
Object ID
Axis ID
Font
Draw valid lines of concrete lines
When marked, distance lines become visible.
Paper Tab
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Border color
Text color
Advanced Paper
Draw steel bar ids
Draw steel lengths
Arrange blocks by name
Draw slab loads
Anchorage length is 1/4
Enable drawing organizer
All stories
Min. distance between blocks
Distance between lines
Table Settings
Table
Table header
Text
Steel drawings
Draw steel bar table
Pile Drawings
JavaScript errors detected
