Skip to main content
Skip table of contents
Shearwall Drawings
With the Shearwall Drawings command, the shearwall detail drawings of the project are prepared.
Location of the Shearwall Drawings Command
  • Click the Shearwall Drawings icon.
  • The Shearwall Vertical Drawing Settings dialog will open.
  • In the drawing properties dialog that opens when you click the Settings button, you can make the desired edits and click the OK button.
  • Make adjustments according to the options in the shearwall vertical drawing settings dialog and click the OK button.
  • The shearwalls of the working story will be automatically designed according to the scale and paper size specified in the drawing settings. One or more shearwall detail windows can be created according to the fit in the paper. The relevant window can be selected from the list under the window menu.
  • In the shearwall details, the shearwalls are arranged in blocks, with rebars and dimensioning lines. You can split the blocks into sub-blocks with the object fragment. In the sub-blocks, again, the object can be divided into lines and writings with shatter.
Multi story
The vertical drawing of the shearwall is prepared completely throughout the entire story.
Single story
The vertical drawing of the shearwall is prepared on the basis of the story where the drawing is prepared.
Group vertically (inter-story) similar shearwalls
The rebar and dimensions of the shearwalls that continue along the stories are compared and similar ones are grouped within themselves and given in a single detail.
Group horizontally (in story) similar shearwalls
The rebar and dimensions of the shearwalls are compared on a story basis and similar ones are grouped within themselves and given in a single detail.
Create plan drawings
The detail view of the shearwall on the basis of plan is given in addition to the vertical expansion.
Draw schematic rebars
Instead of drawing the horizontal and vertical reinforcements of the walls one by one, the drawing is created by giving only the reinforcement diameter and spacing.
Individual longitudinal rebar drawings for grouped shearwalls
Individual longitudinal rebars are drawn for grouped shearwalls
Generate reinforcement steels
Reinforcement steels are drawn.
Middle part schematic only
The middle part schematic only option is active when selected. The horizontal and vertical rebars in the middle part of the shearwall, excluding the header area, are shown in schematic drawing.
Settings
Opens the dialog where drawing properties can be set.
Settings - Drawing Properties
General Tab
Specifications - Colors
Background color
Rebar text
Sets the color of the rebar text. When the color box is clicked, the appropriate color is selected from the window that opens.
Longitudinal rebar
Sets the longitudinal rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
Stirrup rebar
Sets the stirrup rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
Horizontal rebar
Sets the horizontal rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
S-Iron rebar
Sets the s-iron rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar ID text
Adjusts the color of the rebar ID text. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar ID circle
Adjusts the color of the rebar ID circle. When the color box is clicked, the appropriate color is selected from the window that opens.
Dimension text
Sets the dimension text color. When the color box is clicked, the appropriate color is selected from the window that opens.
Dimension line
Sets the dimension line color. When the color box is clicked, the appropriate color is selected from the window that opens.
Object ID
Object body
Detail block line color
Sets the line color of the detail block. When the color box is clicked, the appropriate color is selected from the window that opens.
Axis line color
Sets the color of the axis line. When the color box is clicked, the appropriate color is selected from the window that opens.
Axis circle color
Sets the color of the axis circle. When the color box is clicked, the appropriate color is selected from the window that opens.
Axis text color
Adjusts the text color of the axis. When the color box is clicked, the appropriate color is selected from the window that opens.
Specifications - Appearance
Rebar text
The height of the rebar text is entered.
Rebar levels displacement
The distance between the two rebar texts is entered.
Dimension text
Object ID
Rebar font
The rebar font is selected.
Dimension font
Dimension font is selected.
Object ID font
Object ID font is selected.
Concrete hatch
It is the hatch type that is valid for concrete. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the look-up table in this dialog.
Shearwall header hatch
It is the hatch type valid for shearwall heading. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the look-up table in this dialog.
Axis label radius
The radius of the axis label is entered.
Axis line type
Axis line type is selected. Clicking the down arrow buttons to the right of the boxes opens the list of line types. From this list, the desired line type is selected by clicking with the left mouse button.
Dimension marker type
The dimension marker type is selected.
Longitudinal rebar circles filled
When the option is selected, the inside of the longitudinal rebar circles are filled.
Advanced Tab
Spacifications
Draw rebar ID’s
If checked, rebar ID’s are shown in the drawings. If not checked, it will not be displayed.
Draw rebar descriptions
If checked, the rebar descriptions are shown in the drawings. If not checked, it will not be displayed.
Arrange blocks by name
Generate elevations
If checked, elevations are shown in the drawings. If not checked, it will not be displayed.
Min. distance between blocks
Distance between lines
Paper Tab
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Table Settings Tab
Table contour lines
Sets the color of the table contour lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Table lines
Sets the color of the table lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Table header texts
Sets the color of the table header texts. When the color box is clicked, the appropriate color is selected from the window that opens.
Text
Steel drawing
Sets the color of the steel drawing. When the color box is clicked, the appropriate color is selected from the window that opens.
Create steel bar table
If marked, the rebars are divided into types and a table is created indicating the number, diameter, length, type and weight, and the rebar quantity is shown in the drawing.
Draw steel bending table
If checked, the rebars are divided into bending types and a table is created indicating the number, diameter, length and type, and the bend is shown in the drawing.
Draw reinforcement table
If checked, the reinforcement table is created and shown in the drawing.
Draw object names table
If checked, the object names table is created and shown in the drawing.
Group steels according to layouts
If checked, the steels are grouped according to the layout and shown in the drawing.
Annotations Tab
Defined annotations are listed.
Preview
There is a preview of the annotation selected from the list.
Annotation width
Annotation width is determined.
Layout number
The layout number is determined.
Create New
The new annotation is created.
Edit
The annotation is edited.
Delete
The annotation is deleted.
Don’t add annotation block to the layout
If it is checked, annotation will not be added to the layouts.
JavaScript errors detected
