Skip to main content
Skip table of contents
Rib Drawings
With the Rib Drawings command, the rib drawings of the project are created.
Location of the Rib Drawings Command
  • Click on the Rib Drwaings icon.
  • The drawing properties dialog will open.
  • Make the edits you want and click the OK button.
  • The type (created in story settings when defining ribs) of the story being worked on will be automatically designed according to the scale and paper size specified in the drawing settings. One or more rib drawing windows can be created according to the fit on the paper. The relevant window can be selected from the list under the Window menu.
  • In the rib drawings, the ribs are arranged in blocks with rebars and dimension lines. You can split the blocks into sub-blocks with the object fragment. In the sub-blocks, again, the object can be divided into lines and writings with explode.
General Tab
Specifications - Colors
Rebar text
Sets the color of the rebar text. When the color box is clicked, the appropriate color is selected from the window that opens.
Steel line
Steel ID text
Steel ID circle
Total reinforcement length
Dimension text
Dimension line
Object ID
Object body
Specifications - Heights
Steel text
Steel ID
Steel - text distance
Steel levels displacement
Dimension text
Dimension - text distance
Object ID
Axis ID
Font
Paper Tab
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Border color
You can choose the border color from the color palette that appears on the screen when you click it. If clicked together with the Shift key, the pen thickness of the relevant color can be adjusted. The pen thickness value entered here is only used in inkjet printers.
Text color
You can choose the color of the text written under the sheet from the color palette that appears when you click it. If clicked together with the Shift key, the pen thickness of the relevant color can be adjusted. The pen thickness value entered here is only used in inkjet printers.
Advanced Tab
Draw steel bar ids
Draw steel lengths
Arrange blocks by name
Draw slab loads
Anchorage length is 1/4
Enable drawing organizer
All stories
Min. distance between blocks
Distance between lines
Table Settings Tab
Table
Table header
Text
Steel drawings
Draw steel bar table
Waffle Drawings
JavaScript errors detected
