Skip to main content
Skip table of contents
Part 55. Generate Select Reports
In this tutorial, generate select reports.
1. Use the Analysis+Design (F9) command.
2. Use the Select Reports command.
3. Enter the project information in the Structural Report Settings dialog.
4. Create the reports.
5. Use the Show Index command.
6. Open the Column Information and Static Results page.
7. Change unit settings.
8. Change Table Header font.
9. Save the report as pdf file format.
JavaScript errors detected
