Skip to main content
Skip table of contents
Part 33. Add Dimensions
In this tutorial, create inner and outer dimensions.
1. Use outer dimension command.
2. Select exterior objects to dimension.
3. Determine the dimensions place.
4. Create the outer dimensions
5. Use inner dimension command.
6. Draw inner dimension line.
JavaScript errors detected
