Skip to main content
Skip table of contents
Keyboard Shortcuts and Toolbars in Ribbon Menu
The user can reflect his own menu to the ideCAD with customization. Commands and sub-commands included in menus, sections and sections are fixed and cannot be changed. Customization can only be done on the vertical toolbar on the left side of the screen and the customizable toolbar on the top edge.
Customizing the Vertical Toolbar
To customize the vertical toolbar, right-click on any point of the vertical toolbar. Click the Customize line from the menu that opens.
Location of Customize Command
You can access the Customize command by clicking the right button of the mouse on any command in the vertical toolbar.
Commands Tab
You can drag any icon from the commands listed by category and drop it on the new/existing toolbar.
Categories
Commands are categorized according to the menu order.
Commands
It contains commands in the selected category.
Description
Provides information about the selected command.
Toolbars Tab
Toolbars are listed on this tab. Some toolbars are highlighted in the list. Checked toolbars appear in the program. Otherwise, it will not appear.
In addition, the program includes automatic toolbar management. Floating toolbars appear automatically, some are not, depending on the command being studied. For example, while in column command, the column floating toolbar is opened by the program. It is closed after exiting the command.
The user opens the toolbars whenever they want and closes them whenever they want.
Toolbars
Available toolbars are listed.
Reset
Resets the changes made in the menu.
Reset all
Resets all toolbars and menus.
New
Creates a new toolbar.
Rename
It changes the name of the newly added toolbar.
Delete
Deletes the selected toolbar.
Show text labels
The help that occurs when waiting on an icon in the toolbar for a while appears.
Keyboard Tab
The list of all commands appears in categories on the Keyboard tab. The user chooses the command they want. It gives information about the command in the description part. Shown if there are any shortcuts defined under available keys. The key or keys that they want to assign from the keyboard are pressed. Information on whether the assigned shortcut key is defined in another command is given under the Press new shortcut key section.
Category
Commands
Current keys
Displayed if there are any shortcuts defined.
The shortcut to be newly defined is entered.
Description
Assign
The new shortcut entered is assigned.
Remove
Cancels an assigned shortcut.
Reset all
Cancels all assigned shortcuts.
Menu Tab
Features of the display styles of the menus are included.
Menu shadows
Provides a shaded image when hovering over lists.
Options Tab
There are properties of the way they display toolbars.
Show screen tips on toolbars
An explanation box appears when the icon is hovered.
Show shortcut keys in screen tips
Large icon
The icons grow larger.
Customizing the Quick Toolbar
Location of Customize Quick Access Toolbar Command
You can access any command in the quick entry toolbar or ribbon menu by clicking the right button of the mouse.
In addition, that command can be added to a customizable toolbar quickly by clicking the Add Quick Entry Toolbar line.
Customize Tab
Choose commands from
The menus are listed.
Commands
The commands in the selected menu are listed.
Add
The selected command is added to the toolbar.
Remove
The selected command is deleted from the toolbar.
Toolbar commands
The commands in the toolbar are listed. The location of the selected command can be changed with the arrow keys.
Reset
Initializes the toolbar.
Show quick access toolbar below the ribbon
It takes the toolbar under the menus as a horizontal toolbar.
Keyboard shortcuts
Opens the customize keyboard dialog for customizing keyboard shortcuts.
Customize Keyboard Dialog
Categories
Commands
Current keys
Description
Assign
Delete
Reset all
JavaScript errors detected
