Skip to main content
Skip table of contents
Gable Wall with Trim to Roof Command
To create gable walls under gable roofs; the wall height is set to a value that will exceed the roof and the "Trim to Roof" command is used.
Follow the steps below;
  • Enter a value for the height of the walls on either side of your gable roof that will cross the roof.
  • Click the Home/Roof/Roof/Trim to Roof icon in the ribbon menu. The Trim to Roof  toolbar will open.
  •  Click the New Trim Group icon in the trim to roof toolbar  .
  • Select the roof with the left mouse button and click the right mouse button.
  • Select your walls and click the right mouse button.
  • The Roof Trim Settings dialog will be displayed.  Click the OK button after the desired settings are made  .
  • The walls you choose will be cut, your gable walls will be formed.
JavaScript errors detected
