Skip to main content
Skip table of contents
Creating New Blocks for Annotations
In ideCAD, there are ready-made blocks that can be added to annotations. Optionally, new blocks are created and annotations are also used. Drawings for the annotations are made into blocks using the Copy to File command.
  • Prepare the drawings to be made into blocks.
  • Select the prepared drawing using the copy to file command.
  • Set the reference point.
  • Save the block by giving it a name in the save block dialog.
  • Import the created block file into the C:\Program Files\ideCAD\ideCAD Structural 10\Annotations folder.
  • Use the attached block file when creating new annotations or editing existing annotations.
Preparation of drawings to be made into blocks
Block drawings with copy to file command
Importing the created block file into the annotations folder
Using the added block file when creating new annotation or editing existing annotations
Parameters Available in Annotations Blocks
While preparing the block for the annotations in the project, using the defined parameters, the information about the parameter is taken from the project and written automatically.
Examples of usage of parameters are as follows.
_Parameter_ : Parameter text written between two underscores is written centered.
Parameter_ : When an underscore is added to the end of the parameter, the text is right aligned.
Usage Step
  • Complete your drawing that will become a block by typing the defined parameters.
  • Turn your drawing into a block with the copy to file command.
The drawing to be made into a block and the defined parameters
Block when used on annotation
List of Defined Parameters
PARAMETER
EXPLANATION
!YAPISAHIBI
Project owner - taken from the project settings dialog
!PROJEADI
Project name - taken from the project settings dialog
!DIZAYN
Designer info - taken from the project settings dialog
!REVIZYON
Revision info - taken from the project settings dialog
!IL
Province info - taken from the select report settings dialog
!ILCE
District info - taken from the select report settings dialog
!DESIGN
Design info - taken from the project settings dialog
!CIZEN
Drawer info - taken from the project settings dialog
!KONTROL
Controller info - taken from the project settings dialog
!DANISMAN
Advisor info - taken from the project settings dialog
!KULLANIMAMACI
Intended use info - taken from the select report settings dialog
!PAFTA
Pipe tap info - taken from the select report settings dialog
!ADA
Urban block info - taken from the select report settings dialog
!PARSEL
Lot NOs info - taken from the select report settings dialog
!ENLEM
Latitude info - taken from the 2018 TDY wizard for analysis settings
!BOYLAM
Longitude info - taken from the 2018 TDY wizard for analysis settings
!BINASISTEMI
Structural system info - Reinforced Concrete / Steel / Steel + Reinforced Concrete
!SUNEKLIK
Ductility info - High / Limited/ Hybrid
!TSTX
Structural type info for X direction
!TSTY
Structural type info for Y direction
!SPECTA
TA info
!SPECTB
TB info
!TOPLAMKAT
Story number info
!KATLAR
Building stories info
!BETONSINIFI
Concrete grade info
!CELIKSINIFI
Reinforcing steel info
!YAPCELIK
Structural steel info
!CEVETKI
Environmental impact class info - taken from the analysis settings dialog
!CEVETKIBILGI
Environmental impact class description - taken from the analysis settings dialog
!ZEMINSINIFI
Soil type info - taken from the analysis settings dialog
!YATAKKAT
Coeff. of subgrade reaction info - taken from the analysis settings dialog
!ZEMINTASIMA
Bearing capacity info of foundation - taken from the analysis settings dialog
!RESPSS
Local soil parameters - Ss
!RESPSBIR
Local soil parameters - S1
!BINAKUL
Building Risk Category (BRC) - taken from the analysis settings dialog
!BINAONEM
Building importance factor - taken from the analysis settings dialog
!DEPREMTAS
Seismic design category (DTS)
!BINAYUKS
Building height category (BYS)
!YDKX
Load bearing system behaviour coefficient info- Rx
!YDKY
Load bearing system behaviour coefficient info- Ry
!DFKX
Overstrength factor info - Dx
!DFKY
Overstrength factor info - Dy
!HYK
Live load reduction coefficient
!YERHAREKETDUZEYI
Seismic ground motion level
!PAFTANO
Sheet number
!REV
Revision number info - taken from the select report settings dialog
!OLCEK
Application scale info - taken from the column application plan drawing settings dialog
!KOLOLCEK
Column scale info - taken from the column application plan drawing settings dialog
!TARIH
Date info - taken from the select report settings dialog
!PPDOSEME_
Slab concrete cover - taken from the slab parameters dialog
!PPKIRIS_
Beam concrete cover - taken from the beam parameters dialog
!PPKOLON_
Column concrete cover - taken from the column parameters dialog
!PPTTEMEL_
Single footing concrete cover - taken from the single foundation parameters dialog
!PPSTEMEL_
Strip foundation concrete cover - taken from the continuous foundation parameters dialog
!PPRDOSEME_
Raft foundation concrete cover - taken from the raft parameters dialog
!PPNKIRIS_
Rib and waffle concrete cover - taken from the rib-waffle parameters dialog
!PPBKIRIS_
Coupling beam concrete cover - taken from the coupling beam parameters dialog
JavaScript errors detected
