Skip to main content
Skip table of contents
Constrain the Section
With the "Use section depth" option in the Section/View settings dialog, a depth parallel to the section/view line is determined and only the section/view of that area is taken.
Usage Steps:
  • Double click on the section/view line to enter the section/view settings dialog.
  • Check the Use section depth option.
  • Enter value for depth.
  • If you want to see the depth in the plan drawing , check the Draw section depth line option.
  • Click Create to get your section/view.
Use section depth option is not active:
Section settings dialog:
Use section depth option is active:
JavaScript errors detected
