Skip to main content
Skip table of contents
Column Vertical Drawings
With the Column Vertical Drawings command, the vertical column expansions of the project are created.
Location of the Column Vertical Drawings Command
  • Click the Column Vertical Drawings icon.
  • The Column Vertical Drawing Settings dialog will open.
  • The columns of the working story will be automatically designed according to the scale and layout size specified in the drawing settings. One or more columns can create vertical drawing windows depending on the fit on the sheet. The relevant window can be selected from the list under the Window menu.
  • In the drawing properties dialog that opens when you click the Settings button, you can make the desired edits and click the OK button.
  • In the vertical drawings of the column, all column-beam joints, rebars and dimension lines are arranged as a block. You can split the blocks into sub-blocks with the object fragment. In the sub-blocks, again, the object can be divided into lines and writings with explode.
Column Vertical Opening Settings
Multi story
Prepares the vertical column of the columns throughout the whole story.
Single story
It arranges the vertical drawing of the columns separately for each story.
Group vertically (inter-story) similar columns
The rebars and dimensions of the columns are compared on a story basis and similar ones are grouped within themselves and given in a single detail.
Create horizontally (in story) similar columns
The rebars and dimensions of the columns are compared within the layer and similar ones are grouped within themselves and given in a single detail.
Create column-beam joint drawings
It becomes active when the single story option is selected. It also creates the column-beam junction area detail above each detail in column openings.
Create plan drawings
If checked, the plan drawing is created.
Generate reinforcement steels
If marked, the reinforcement steel is drawn.
Settings
Opens the dialog where drawing properties can be set.
Settings - Drawing Properties
General Tab
Background color
Rebar text
Sets the color of the rebar text. When the color box is clicked, the appropriate color is selected from the window that opens.
Longitudinal rebar
Sets the longitudinal rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
Stirrup rebar
Sets the stirrup rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
Horizontal rebar
Sets the horizontal rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
S-Iron rebar
Sets the s-iron rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar ID text
Adjusts the color of the rebar ID text. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar ID circle
Adjusts the color of the rebar ID circle. When the color box is clicked, the appropriate color is selected from the window that opens.
Dimension text
Sets the dimension text color. When the color box is clicked, the appropriate color is selected from the window that opens.
Dimension line
Sets the dimension line color. When the color box is clicked, the appropriate color is selected from the window that opens.
Object ID
Object body
Detail block line color
Sets the line color of the detail block. When the color box is clicked, the appropriate color is selected from the window that opens.
Rebar line (lower floor)
Adjusts the color of the lines showing the rebar in the lower story. When the color box is clicked, the appropriate color is selected from the window that opens.
Specifications - Appearance
Rebar text
The height of the rebar text is entered.
Rebar levels displacement
The distance between the two rebar texts is entered.
Dimension text
Object ID
Rebar font
The rebar font is selected.
Dimension font
Dimension font is selected.
Object ID font
Object ID font is selected.
Concrete hatch
It is the hatch type that is valid for concrete. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the look-up table in this dialog.
Shearwall header hatch
It is the hatch type valid for shearwall heading. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the look-up table in this dialog.
Dimension marker type
The dimension marker type is selected.
Longitudinal rebar circles filled
When the option is selected, the inside of the longitudinal rebar circles are filled.
Advanced Tab
Draw rebar ID’s
If checked, rebar ID’s are shown in the drawings. If not checked, it will not be displayed.
Draw rebar descriptions
If checked, the rebar descriptions are shown in the drawings. If not checked, it will not be displayed.
Arrange blocks by name
Generate elevations
If checked, elevations are shown in the drawings. If not checked, it will not be displayed.
Min. distance between blocks
Distance between lines
Paper Tab
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Table Settings Tab
Table contour lines
Sets the color of the table contour lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Table lines
Sets the color of the table lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Table header texts
Sets the color of the table header texts. When the color box is clicked, the appropriate color is selected from the window that opens.
Text
Steel drawing
Sets the color of the steel drawing. When the color box is clicked, the appropriate color is selected from the window that opens.
Create steel bar table
If marked, the rebars are divided into types and a table is created indicating the number, diameter, length, type and weight, and the rebar quantity is shown in the drawing.
Draw steel bending table
If checked, the rebars are divided into bending types and a table is created indicating the number, diameter, length and type, and the bend is shown in the drawing.
Draw reinforcement table
If checked, the reinforcement table is created and shown in the drawing.
Draw object names table
If checked, the object names table is created and shown in the drawing.
Group steels according to layouts
If checked, the steels are grouped according to the layout and shown in the drawing.
Annotations Tab
Defined annotations are listed.
Preview
There is a preview of the annotation selected from the list.
Annotation width
Annotation width is determined.
Layout number
The layout number is determined.
Don’t add annotation block to the layout
If it is checked, annotation will not be added to the layouts.
Create New
The new annotation is created.
Edit
The annotation is edited.
Delete
The annotation is deleted.
Beam Drawings
JavaScript errors detected
