Skip to main content
Skip table of contents
Column Application Plan
Column application plan of the project is prepared with the Column Application Plan command.
Location of the Column Application Plan Command
  • Click on the Column Application Plan icon.
  • The column application dialog will open.
  • In the drawing properties dialog that opens when you click the Settings button, you can make the desired edits and click the OK button.
  • Click one of the options: details on place, details outside, tunnel formwork header details outside, reinforcement on place and reinforcement outside.
  • According to the option you clicked, a column application plan will be prepared.
Column Application Dialog
Select stories
Mark the stories for which you want to get a column application plan.
Drawings on single window
Column application plans of all marked stories are prepared in a single operating window. If the option is not selected, each story will be applied in separate working windows.
Drawings on single layout
Column application plans of all marked stories are placed in a single layout. If the option is not selected, each layer will be applied as separate layouts.
Select/Deselect all
It marks all stories or cancels those with a sign.
Settings
Opens the dialog where drawing properties can be set.
Details on place
When applying the columns, it also enlarges them and details them on site.
Details outside
While applying the columns, leaves them in 1/50 plan view and prepares the details separately at the edge of the sheet.
Tunnel formwork header details outside
It prepares the applications of tunnel formwork projects.
Reinforcement on place
Prepares the applications of the reinforcement projects. This option also enlarges and elaborates the columns on the spot when applying.
Reinforcement outside
Prepares the applications of the reinforcement projects. This option leaves them in 1/50 plan view while applying the columns and prepares the details separately at the edge of the sheet.
Settings - Drawing Properties
General Tab
Specifications - General
Background color
Column/shearwall color
Sets the column/shearwall color. When the color box is clicked, the appropriate color is selected from the window that opens.
Name color
Sets the name color. When the color box is clicked, the appropriate color is selected from the window that opens.
Name height
Name height is entered.
Column hatch
It is the hatch type that is valid for column. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the hatch table in this dialog.
Shearwall hatch
It is the hatch type that is valid for shearwall. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the hatch table in this dialog.
Basement shearwall hatch
It is the hatch type that is valid for basement shearwall. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the hatch table in this dialog.
Reinforcement hatch
It is the hatch type valid for reinforcement. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the hatch table in this dialog.
Shearwall header hatch
It is the hatch type valid for shearwall header. Clicking on hatch opens the Hatch Settings dialog. The hatch type is selected from the hatch table in this dialog.
Specifications - Dimensions
Line color
Sets the dimension line color. When the color box is clicked, the appropriate color is selected from the window that opens.
Text color
Adjusts the text color. When the color box is clicked, the appropriate color is selected from the window that opens.
Text height
Size text height is entered.
Marker type
The marker type is selected.
Specifications - Fonts
Name font
Name font is selected.
Axis font
Axis font is selected.
Length font
The font of the length text is selected.
Diameter font
Diameter font is selected.
Specifications - Rebar
Longitudinal rebar color
Sets the longitudinal rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
Stirrup rebar color
Sets the stirrup rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
Horizontal rebar color
Sets the horizontal rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
S-iron rebar color
Sets the s-iron rebar color. When the color box is clicked, the appropriate color is selected from the window that opens.
Length text color
Sets the color of the length text. When the color box is clicked, the appropriate color is selected from the window that opens.
Diameter text color
Sets the color of the diameter text. When the color box is clicked, the appropriate color is selected from the window that opens.
ID text color
Adjusts the color of the ID text. When the color box is clicked, the appropriate color is selected from the window that opens.
ID circle color
Sets the ID circle color. When the color box is clicked, the appropriate color is selected from the window that opens.
Length text height
Text height is entered.
Diameter text height
Diameter text height is entered.
Longitudinal rebar circles filled
When the option is selected, the inside of the longitudinal rebar circle is filled.
Specifications - Axis
Inside line color
Sets the axis inside line color. When the color box is clicked, the appropriate color is selected from the window that opens.
Outside line color
Sets the axis outside line color. When the color box is clicked, the appropriate color is selected from the window that opens.
Circle color
Sets the axis circle color. When the color box is clicked, the appropriate color is selected from the window that opens.
Text color
Adjusts the text color of the axis. When the color box is clicked, the appropriate color is selected from the window that opens.
Text height
Text height of the axis is entered.
Label radius
The radius of the axis label is entered.
Inside line type
The line type of the axis inside line is selected. Clicking the down arrow buttons to the right of the boxes opens the list of line types. From this list, the desired line type is selected by clicking with the left mouse button.
Outside line type
The line type of the axis outside is selected. Clicking the down arrow buttons to the right of the boxes opens the list of line types. From this list, the desired line type is selected by clicking with the left mouse button.
Draw inner axis lines
When the option is selected, axis inner lines are drawn.
Advanced Tab
Application scale (1/X)
Application scale is entered.
Column scale (1/X)
The column scale is entered.
Paper height
Standard paper sizes
Vertical/Horizontal use
Layout border color
You can select the layout border color from the color palette that appears when you click it. If clicked together with the Shift key, the pen thickness of the relevant color can be adjusted. The pen thickness value entered here is only used in inkjet printers.
Detail border color
You can select the detail border color from the color palette that appears on the screen when you click it. If clicked together with the Shift key, the pen thickness of the relevant color can be adjusted. The pen thickness value entered here is only used in inkjet printers.
Draw steel bar tables
If checked, rebar tables are added to the drawing.
Draw reinforcement tables
If checked, the object reinforcement table is added to the drawing.
Contour lines color
Sets the color of the table contour lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Line color
Sets the color of the table lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Header text color
Sets the color of the table header texts. When the color box is clicked, the appropriate color is selected from the window that opens.
Text color
Rebar color
Sets the color of the rebar. When the color box is clicked, the appropriate color is selected from the window that opens.
Draw steel bar ids
If checked, theids of the rebars are shown in the drawings. If not checked, it will not be displayed. If desired, crossties are included.
Draw rebar descriptions
If checked, the rebar descriptions are shown in the drawings.
Annotations Tab
Defined annotations are listed.
Preview
There is a preview of the annotation selected from the list.
Annotation width
Annotation width is determined.
Layout number
The layout number is determined.
Create New
The new annotation is created.
Edit
The annotation is edited.
Delete
The annotation is deleted.
Don’t add annotation block to the layout
If it is checked, annotation will not be added to the layouts.
Shearwall Drawings
JavaScript errors detected
