Skip to main content
Skip table of contents
Changing the Material of the Curtain Wall Panels
The materials defined in curtain wall panels are changed by using the command "Edit curtain wall item".
Usage Steps:
  • Click the Edit curtain wall item command.
  • Click on the panel whose material you want to change.
  • Select one of the general, type 1, type 2 and type 3 options from the curtain wall settings dialog that opens.
  • Click the OK button to close the dialog. The material of the panel you selected will change.
JavaScript errors detected
